Customized flange heater
momu253
Appliaction:
Water immersion electric coil heater element is used for Water heater and similar home products.
Heating element are produced using Incoloy840, stainless steel 304, 321, 310S, sheath materials
and also there is huge variety of selection of termination styles available.Defrost heater are custom designed in a various
shapes to address client’s requirements.
Detailed Information
Dimeter
of tube6.5mm
8.0mm
8.5mm
9.0mm
10mm11mm12mm14mm16mm
MaterialAISI304*AISI321*AISI316AISI310SINCOLOY840
Length of tubeFrom 200mm to 6500mm, The length will be manufacture it according to custom’s require
Length of wireFrom 200mm to 2000mm, The length will be manufacture it according to custom’s require
ColorColor of tube is yellowish*or Dark-green or Black
Feature:
1.We offer standard as well as customized models
2.We offer different tube diameters like 6.5 mm, 8 mm, 8.5mm,9mm,10.6mm,11mm& 12mm, 14mm,16mm and so on.
3.We offer different sheath materials. It can be availed in different materials like Incoloy 840, SS 304, SS 321, SS 316,
Aluminum
4. Ambient temperature: -60°C ~ +800°C
5. High- voltage in Test : 16,00V/ 5S
6. Firmness of connection end: ≥50N
7. Protective oxide coated element wire for long-term heater life
8. Can be manufactured to proper length
Technology data:
1.HI-POT TEST: 1600V/S on normal temperature
2.Insulation resistance:500MΩ
3.Leakage current to be 0.75ma max While energized at rated voltage
4.Power tolerance:+5%,-10%
5.Voltage:12V-440V
6.Diameter range:4.5mm to 20mm
7.Heating resistance wire:0Cr25Al5,Cr20Ni80 or as custom'es requirement
7.Air tubular heater wattage : ≥ 1w-5w/cm2
We can send the sample to you for free. you can test our qanlity!!Customized flange heater
website:http://www.benoindustry.com/heating-tube/boiler-heating-element/
Back
